Tire size / Drop Question
fire730
Louisiana
Would a 275/55/20 on OE GM 20s clear with a 3/5 drop on an 04 Yukon XL? I want to lower it but I do not need new tires yet and I am sure if I go with a 2/3 first I will want to go lower later. Thanks.
ohiokon
I know what you mean about the 2/3 not being enough. My 2/3 has been on for 2 weeks and my 3/5 is on it's way from Tony! i have the factory 20's with the same size tire as you. I will be installing the kit and helper bags and a belltech rear sway bar plus the free travel mod this Fri if everything goes as planned and I will post the results. Some 24's are next!
Max
Mile High
Denver
Will rub the sway bar at full crank but they should clear well, trim the rear fender liners and flip the upper shock bolts in back if you haven't already :cheers:
Travieso
Boooooooost !
Los Skandeles, CA
i have a 3/5 drop with 24's 305/35/24 No problems what so ever, i did have to do alot of plastic trimming to the front especially to the back.. but other then that a little rubbing in the front driver side firewall only when i fully lock in turns
AdrienR
