Tire Pressure
kaiserwillie
I have 2016 Yukon SLT 4x4 with 51k miles on it since new. What tire pressure are most of you using on stock tires especially in the summer. Im doing more city/stop and go driving and was wondering if I should stay with 35 psi which is on the door label.
for normal every day driving it's not that critical, just run your tires at whatever the sticker says, you could drive your entire life and never see a difference in 5 psi over or under the door sticker, if you ran them under for thousands of miles you might see some odd outer tread wear
if you were towing or hauling around a heavy load 24/7 I would over inflate a smidge, otherwise no
Capybarbro
