Throttle adjustment
PUGLIA
Oklahoma
This may be old news to some but it's new to me. I never could figure out why my hoe was so slow or dragged off the line. I checked everything and cleaned everything. But it always had a delayed response when I pushed the throttle. The other day I watched carfix and it mentioned a product called speed booster. I thought I would check it out. It's supposed to increase throttle response. Well they don't make it for 00-06 tahoes. So I did some searching and found a thread that described how to adjust your throttle response. I really didn't even pay much attention to it but I saved the page and said I would try it. Well I just did and DAMN!
Here's how you do it:
- Get in the truck shut the doors buckle the seat belt.
- put the keyin the ignition and turn it to the on position ( do not turn it over)
- press the pedal down as quick as possible and hold it to the floor
- turn the key to the off position
- wait a few seconds the. Release the pedal.
That's it!
I turned the truck on to check it out and about redlined the truck less than half way to the floor. Check it out!
-----PUGLIA-----
franksbanks
Arizona
That's it!
-----PUGLIA-----
sweet, im trying this tonight! :peace:
redemn93
Jupiter, Fl
sounds like its recalibrating the TPS so that computer adjusts timing and fuel curve more appropriately.
Yukonboy2014
Just did it. I did notice that the chime that normally sounds when you switch to 'on' did not chime during the process. Will see how it performs in the morning.
ChiefTW
