The twin hoes plus one
Sparksalot
Sparksalot
Bastrop County, Texas
White was what I was thinking too.
The painting was going so well, then the wind came up. Ugh. I’ll probably just strip them and start over.
Sparksalot
Sparksalot
Where did you get the strobes on the push bar? Can you alternate the flashes?
They are Feinix strobes. i found them on eBay for $29 each, about the going rate anywhere. The patterns can be changed by just grounding a signal wire. Right now I’ve kept them in synch, but could change them individually by unplugging one or the other. I’m not running them through a controller or other synch device.
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
I got this strobe switch from Superbrightleds. On/off with a ground signal button to change the pattern.
cooki3mnster
Trucks looking good with the vents!
Are you running a mobile HAM setup? what are you using for antenna/mount? I'm looking for ideas on how to mount my uhf/vhf antenna for my Icom 4100.
Sparksalot
Sparksalot
In thecopcar, I added some snap on RF chokes to the power cords for both the refrigerator and one of the ham radios. The frig has been driving that radio nuts since I installed it.
the other radio has been quiet since the chokes were added to the fridge cord.
wide open squelch on an FM radio sux.
Sparksalot
Sparksalot
Was under hood in theothertwin today and noticed it has the battery isolation relay option. Not sure why I never noticed it, but bam there it is. DPS or the upfitter bypassed it however, since all the cables are attached at the upper terminal only.
ibarra503
