tahoe not responding when i floor it
payanhilario
my 2001 tahoe does not respond like if i push the gas pedle to the floor it dosent respond like it should but when i step on it slowly it kinda does but not really rpm wise any ideas why
Physh1
Have you changed your fuel filter lately? Air cleaner clean? Tuned up lately?
Your 11 years old? Lol...
blueflamed03
Oklahoma
describe "does not respond?"
Doesnt rev? slow to rev?
sounds like plugged fuel filter.
Clogged cats?
etc.
DenaliAK
Colder than you
Alaska
Fuel filter, fuel pump....
Really, really dirty air filter...
droppedHoe
Lawrenceville,Ga
i had the same issue when i had my 02hoe.
it use to spin the tires at a red light when i floored it, then over time it kept loosing a step.
had a fresh tune up with plat plugs, new plug wires, sea foamed, maf cleaned, changed the fuel pump, filter and had a spectra on it... didnt change acceleration wise though
never thought about the cat though... i did have 204k miles on it with the original cat...
clogged cat, you might be right there Tracy
droppedHoe
Lawrenceville,Ga
How do you fix a "clogged cat" or do you replace it?
has to be replaced. depending on where you live and how emissions are or if there's emissions you may be able to do a straight pipe but a Magnaflow cat locally here in atlanta is about $70 plus labor.
Ep33401
