Tahoe not level
JKmotorsports
Austin, TX
if i go ahead and do this, what does it do to my alignment?
Your camber will become affected mainly. The toe will also, but not as significantly as the camber. The lower you go, the more you put the wheels in negative camber. Lifting will put the wheels into positive camber. When the control arms are moved up and down, this also changes the angle of the tie rods, although it is very minimal. And when that happens, the distance between the centerlink and steering knuckle changes, affecting the toe. If you don't have a problem with abnormal tire wear now, you will afterwards if you don't get it re-aligned.
Grebbler
Parts is parts...
Michigan
Say a person is 1 inch off. Raising one side 1/2 inch and lowering the other 1/2 would cancel out the toe changes (with a tiny shift of the steering wheel to off center), wouldn't it?
When the shop aligned mine after cranking it up (against my wishes) the toe was the only thing out of spec.
MOBmentality
Has a $25,000 Punch
yea mine sits higher on the passenger side too, thought it might be cus im always sitting on driver side and im 6'3 250lbs lol
lol uh ohhhh here comes the new forum challenge.. body weight of driver.. lol
mine sags a little... when im in it... 6'3 272lbs
tybardy
tybardy
everyone needs a Hoe
Gilbert Arizona
yea this thought actually crossed my mind... the weight of the driver + fuel tank saging the truck on that side... even still, i want it ******* fixed, its horse shit
danimalmax
louisiana
why would the weight of the driver have anything to do with it? who can see the outside of their car while they're sitting inside anyway?
tybardy
tybardy
Gilbert Arizona
my thought was, that 5 years of weight being distibuted to one side of the truck more then the other is what made it sag on the driver side
mtglick
