Tahoe not level
tybardy
everyone needs a Hoe
Gilbert Arizona
So my front driver side sits about a full inch lower then the front passenger side and the rear driver side sits about a half inch lower the the rear passenger side...
Any ideas on how to fix el problemo?
BOSS
The People's A D M I N
Dallas
Mine does too, I think it has something to do with how much the driver side of the truck body shifts a little upwards upwards on initial acceleration personally...maybe the body mounts are a little more compressed on the driver side? Dunno the answer on that one.
I'm going to correct it with body drop but for now I just pulled down the front pass side a little with my keys and removed the rear spring isolators. When I removed the isolators I wrapped the springs with a little thin rubber from a water hose I spliced. What I did to compensate for the higher pass side was to add a little more rubber on the driverside (edited) rear spring. It did help, but being a perfectionist I still the the difference and so does my measuring tape. :D
I finally contributed to someone's problem, pretty damn proud of myself! Gotta give back!
BOSS
---------- Post added at 07:42 PM ---------- Previous post was at 07:39 PM ----------
I have a 3/5 drop, not sure if you have dropped yours or not but it doesn't look like it. Still you should be able to do what I did to alleviate the height difference some..make it tolerable anyway.
Don't forget, measure from the wheel lip to the body. Some ******* tried to measure my shit at a shop when I was looking into this body drop thing...moron was measuring from the rock gravel pavement to the truck body.
BOSS
tybardy
tybardy
Gilbert Arizona
well, now this brings me to my next question for you... you might be two for two today
how do you adjust the front keys?
BOSS
Dallas
There is a hex bolt for each key under the truck just about the middle way down the body of the underside...follow the long suspension bars from the front suspension, they end and slide into the "keys". Then underneath where those bars end, are two bolts that you can loosen to lower and tighten to raise.
BOSS
BOSS
Dallas
BOSS
Sorry I meant added more rubber on the driverside rear spring to raise it up a hair.
---------- Post added at 08:13 PM ---------- Previous post was at 08:12 PM ----------
page 2 of this pdf will show u where the bolts are, ignore the rest of the instructions
http://z71tahoe-suburban.com/iboard/index.php?act=attach&type=post&id=2
Tried it but I guess you gotta register
BOSS
---------- Post added at 08:15 PM ---------- Previous post was at 08:13 PM ----------
Here is a picture of the bolt
http://www.truxxx.com/chevrolet_products/chevrolet_images/1999_21.jpg
danimalmax
louisiana
if i go ahead and do this, what does it do to my alignment?
it'll bow it in to the middle or outwards, depending on whether you lower or lift, the recommended thing to do is adjust your bolts, drive around the block and make sure u like where its at, then go get an alignment so one side of your tires dont get worn
BOSS
Dallas
Sorry - I forgot to mention that important part! Must get an alignment.
Also, try two full turns of the torsion bolt at a time, should give you exactly what you need each time you do it so you don't under, or over do it. Drive around the block like a those guys do in nascar on caution flag, turn your steering wheel from side to side and level the suspension out. I get funny looks in my hood when I do this. :driver:
BOSS
MOBmentality
Has a $25,000 Punch
BOSS
if it is sagging is suspension based (99.9%) and hasnt been aligned since the sag then adjusting it back level on on said would actually fix the alignment back to zero
JKmotorsports
Austin, TX
Your camber will become affected mainly. The toe will also, but not as significantly as the camber. The lower you go, the more you put the wheels in negative camber. Lifting will put the wheels into positive camber. When the control arms are moved up and down, this also changes the angle of the tie rods, although it is very minimal. And when that happens, the distance between the centerlink and steering knuckle changes, affecting the toe. If you don't have a problem with abnormal tire wear now, you will afterwards if you don't get it re-aligned.
Grebbler
Parts is parts...
Michigan
Say a person is 1 inch off. Raising one side 1/2 inch and lowering the other 1/2 would cancel out the toe changes (with a tiny shift of the steering wheel to off center), wouldn't it?
When the shop aligned mine after cranking it up (against my wishes) the toe was the only thing out of spec.
MOBmentality
Has a $25,000 Punch
yea mine sits higher on the passenger side too, thought it might be cus im always sitting on driver side and im 6'3 250lbs lol
lol uh ohhhh here comes the new forum challenge.. body weight of driver.. lol
mine sags a little... when im in it... 6'3 272lbs
tybardy
tybardy
Gilbert Arizona
yea this thought actually crossed my mind... the weight of the driver + fuel tank saging the truck on that side... even still, i want it ******* fixed, its horse shit
danimalmax
louisiana
why would the weight of the driver have anything to do with it? who can see the outside of their car while they're sitting inside anyway?
tybardy
tybardy
Gilbert Arizona
my thought was, that 5 years of weight being distibuted to one side of the truck more then the other is what made it sag on the driver side
Charlie21ny
