Symptoms: dying oil pump?
Derick
Indy Suburbs
So a few around here have been seeing my sporadic posts about my potentially problematic suburban 2500. My 6.0L has about 145k on it. I have seemingly always had lifter noise while in my possession but recently a thunking knock came about. I feel like that is a loose or broken exhaust stay since the exhaust manifolds were replaced.
So anyhow, today a few things started lining up during a short road trip. I've been trying various snake oil treatments, with no change.. Shocker I know... But maybe they are helping at I'm starting to loosen things? I dunno... Anyhow in the past I was getting an indicated ~50 on the oil pressure gauge at startup and speed and about ~30 on idle. Recently, I've been showing 40 at speed and 20ish at idle. Lifter chatter is going pretty good at idle. I feel like things have deteriorated in regards to oil pressure and that might be the source of my problems. Thoughts?
Derick
Derick
Indy Suburbs
Bringing this thread back up since it is related but earlier today I actually recorded some video and wanted to get the community opinion of my oil pressure. Is this falling within expectation? I feel like it's low but I also have no frame of reference and I'm just some guy so what do I know. Let me know what you think.
The beginning is idle, the middle is cruising speed and the last bit is wide open.
even with a brand new engine, oil pump and sensor mine does basically the same thing depending on if it's warmed up or not
Durobans
