Sunroof air deflector clips?
Sam Harris
Texas
So my ‘03 Yukon has a sunroof, and the factory air deflector piece is not popping up like it’s supposed to, due to both spring clips being broken. I believe it’s part # 88980678, but not certain, and I can’t seem to find anyone that sells these either. Can anyone confirm the part number, or recommend an alternative that will work?
Sent from my iPhone using TapaBlah
Matthew Jeschke
Sahuarita, Arizona
Have you looked on gmpartsdirect.com
Id look for you but am at my phone and hate using it for such things. Is just to hard to work at.
They have exploded diagrams and parts breakdowns to build most gm cars and trucks.
Sent from my SM-G925V using Tapatalk
PG01
Up here to the right
getting same info on searchs
Sam Harris
Sam Harris
Texas
Thanks. I think I looked there, but will double check.
Sam Harris
Sam Harris
Texas
That sucks, maybe is a junkyard only part. My truck didnt have the deflector either when i bought it :|
Yeah, hoping to get replacements. Seems like it should be a fairly common part to break, and need to have stocked. [emoji53]
adventurenali92
Big Bear Lake, ca
@adventurenali92 , chase didn’t you have something going on with your sunroof?
Not with the air deflector. The plastic track pieces that guide it back and forth broke so it doesn’t slide back. That’s the most common sunroof related issue on our gen truck. I’ve never seen issues with the air deflector. But I’m not surprised as it’s all plastic pieces.
adventurenali92
Big Bear Lake, ca
Check out tgautomotive.com. They may have a solution for your spring clips. Also take a look at gruven parts. They make a ton of GM related stuff. Metal replacements for shotty plastic pieces that break.
Stupidgm62motor
