Sunroof accessory
2019YukonXLowner
Hi!
When driving at higher speeds, the sunroof being open is so loud. Has anyone found an accessory that helps with this?
Thanks!
16yukondenali
WeatherTech used to have them for the previous generations. I loved the one on my 2004 Denali- no wind noise at highway speeds. I would be interested if anyone has found something too.
there are visor's out there that may help never tried one, generally if you only have the sun roof open it shouldn't be too bad, otherwise the noise is just inherent to having a sun roof open they didn't design it for high speed. the visor's out there are stick on and generic you would just need to measure the width needed and shop.
BeenChevy
Minnesota
Haven't tried a wind deflector but you can zip-tie the pop-up windscreen at the front of the moonroof which cuts down the noise considerably. After a few long road trips, I ended up doing this to prevent the noise and it worked well.
Tupapi
