Stability/Traction light WTF!!!!!!
anton28
Driving home today and my Traction light/Stability light comes along with a brake light. Brake light turns off but my traction/stability stays on. About 10 minutes later the brake light comes back on and again turns off and this cycle continues the entire 1 hour drive home. My front and rear brakes have 5k on them so I know its not that.
Any suggestions what I should look for or what it could be?
jolliges
What spindles are you using? does it mainly happen while you are turning?
Not trying to hijack this thread but, I'm having the same problem with my 07 Hoe ever since I installed my Belltech drop. And it mainly happens when making left turns.....
bodymccannx
Hey guys. I also had this issue; I thought I remembered it occurring a couple of times prior to lowering the truck. After I installed the Belltech 2/3 drop, it seemed to occur all the time when making low speed turns, left or right. GM has a TSB on this issue "Unwanted low-speed ABS activation", which suggests cleaning the corrosion the collects on the mounting surface b/w the ABS sensor and the wheel hub. I had this done and did not correct the problem; GM techs finally performed a reflash of the ECBM and (knock-on-wood) it has not happened since. Hope this info helps.
anton28
anton28
Wow that was easy!!!! It was just low brake fluid LOL All of that commotion just for low brake fluid. WTF GM?!?!?
dizhai
