squeaking sound from front while turning wheel
Tatman48
Hey all, my 08 yukon xl denali just started this am. when sitting still, as I turned my wheel and start moving I noticed a loud squeaking sound. all ball joints and tie rods seem tight and have no play. but is almost sounds like rubber binding but I cannot locate the culprit. My wheel bearing is tight with no play either. I replaced bearing on passenger side but drivers was still good. it will do it when sitting idle or moving has anyone had any of these issues?
T
Tatman48
yes I am sure. wife called me after dropping her off at work and said it was loud and sounded real bad it sounded like my chrysler 300 did when I installed poly bushings onmy sway bar and forgot to grease them, but i didnt do that. and no it wasnt super cold, been colder but definitely started today. I had heard it before but it stopped. but recently
petethepug
Michael
SoCal
Well, here too on our 08 Denali XL and the squeaking on ours is occurring when the wheel has is turned and sounds like fluid being restricted or getting past an O ring in the steering rack.
This started when we had the rack replaced last month. Our tech is aware of it and stumped too. It’s going in for some other work next week and he’s going to either condemn the rebuilt AC Delco rack or pump for replacement.
T
Tatman48
Mine is lower ball joint ... I used a grease gun needle and injected the boot and sound went away .I am waiting for new ball joints co come in
dnt1010
Tennessee
Most likely both upper and lower ball joints are dry. Factory joints do not have grease fittings (thanks GM) As stated in the previous thread a grease needle is the easiest solution just fill the boot with grease and drive happy. If you let it go very long it starts sounding like this!!!!!!!!!!
VERY ANNOYING
petethepug
Michael
SoCal
Yea, that’s squeak, mine rack is a moaner. That’s was GM calls non serviceable, lifetime lubricated [emoji23]
dnt1010
Tennessee
Only way to properly diagnose is to remove the wheels and remove the tie rods and then turn each piece individually including the steering rack. The sound reverberates through the entire system and it is almost impossible to isolate it without doing this procedure. Good Luck
Bmorey67
VERY ANNOYING
This sounds like my truck! Thanks so much for sharing. I wake up my whole neighborhood whenever I pull up in or leave my driveway. I didnt realize it was so bad because I have my radio up so loud lol. I will add grease and report back. Thanks again.
brice715
