spun out now check engine light is on
DJTricky
Banned
Robbinsdale MN
so i totally just spun out on the highway exit ramp, my engine stalled out and now im throwing a check engine light. i cant scan it yet, any ideas on what it could be? i was rolling backwards for about 20 feet wile still in drive. is this bad?
BlizzardX23
Sacramento, California
Seems like that part would be an issue.. :shrug:
What happened...was it snowing or something?
ravingmadman
Chief Knuckle Buster
Greater Seattle
Raving Madman loves snow. Good job not wrecking your rig. I don't think rolling backwards would have hurt it, if you've got an automatic. Turn it on/off a couple times, see if the light goes off, as per one of the other threads. If the light doesn't go away, you know we're here for you, waiting for your codes...
:drunk:
D
DJTricky
Banned
Robbinsdale MN
going to get it checked out now. lets all pray for the best.
---------- Post added at 01:52 PM ---------- Previous post was at 01:06 PM ----------
well the good news is its not as bad as i thought.
i threw 4 codes
P0108 - MANIFOLD ABSOLUTE PRESSURE (MAP) to high
P1345 - Crankshaft Position (CKP)-Camshaft Position (CMP) Correlation
P0700 -Transmission Control System Malfunction
and
P1100 - MAF Intermittent(to much airflow)
all went away after scan. none exist now :)
BlizzardX23
P0700 is what caused the check engine light to come on. Because you spun out and the truck got thrown backwards while in drive, it probably noticed an issue...glad its all good now!
Drive it then check it again though to be sure
D
DJTricky
Banned
Robbinsdale MN
i will for sure be driving it lol im gonna check them again tomorrow so we will see if it is all good now.
BlizzardX23
Remember, these trucks are smart now...and everything is computer controlled...because the "Drive" gear wasnt meant to go in reverse, it will alarm the system that there is an issue. :)
Lets us know 2moro the results
JPeter
