Speedometer not reading correctly.
PanchohasAyukonno
Hi there looking for some insight/guidance, first time with GM and first Yukon 2008 5.3 200k miles, I need some help my speedometer is 10mph off it reads higher than the speed im going. I would like to know where to start a sensor, abs wheel speed sensors or even looking in tune or am I over thinking it. Thank you in advance.
strutaeng
Dallas, Texas
You just bought the vehicle? Do you know the history?
Agree on confirming you are running the stock tire size...
Other possibilities are: previous owner swapped the rear end and didn't recalibrate the ECU, or swapped the ECU, and again, didn't recalibrate it to the correct gear ratio. Who knows?
Marky Dissod
... speedometer is 10mph off ...
At what actual MpH is your speedometer off by 10MpH?
If it's ALWAYS off by 10MpH, that's the needle's stepper motor, methinks.
Even if it's not, your'll likely need to pull the driver info center out of the instrument panel.
If it's off by 10MpH at a certain MpH, less under that MpH, more over that MpH,
that's either your tires, or your pcm tune, most likely.
Welcome to the Forum from NH.
Pics of the truck, please.
P
PanchohasAyukonno
Using gps it says I’m going 70 but the speedometer says 80 with the scanner I have ecu says I’m going 80 and with a car pacing me actual speed is 70
P
PanchohasAyukonno
Yeah just bought it so I know nothing about it what’s been done to it, everything seems to look stock other than air intake and a spacer lift in the front
P
PanchohasAyukonno
