[SOLVED] Service Driver Assist
martinajm
Yesterday I was the victim of a loose cardboard box flying out of a truck on the freeway. I had no option of go around it and took it low on the front end. Only visible evidence is a slightly bent license plate bracket, but it is barely noticeable. However, shortly after I received a "Service Driver Assist" message, which is repeatable every time that I start the vehicle now.
Any insight / suggestions on this? I would like to avoid having to leave it at a shop to address this - or is there a way to perhaps just disable the driver assist?
Groucho
I had the same on my new Tahoe...It ended up being one of the camera's wire came loose. Sounds the same.
Could be a camera issue, or it could be that a front proximity sensor got knocked, when the box hit the front of the truck.
M
martinajm
All of my cameras seem to be working, unless there is another camera that is dedicated to Driver Assist that does not come up on the display?
M
martinajm
Sensor in the front bumper had to be replaced. Cheap part - lots of labor...
JPeter
