side mirror blinker replacement?
ReaperHWK
2015 Tahoe LTZ. My passenger side blinker (the arrow on the sideview mirror) the LED's need replaced. They are very dim.
Does anyone know the lowest replaceable assembly for this? Can I just replace the LED board, or do I have to replace the entire glass, or do I need the whole mirror?
Thanks.
ReaperHWK
ReaperHWK
Anyone pull the glass before? Any tips?
ReaperHWK
ReaperHWK
Use your fingers it is easy to pop out
That’s what I thought. However I found this video saying you need to pry it up first. I guess I’ll look at the new one and check out the clips.
RST Dana
EMT/First Responder Firefighter Supporting Member
OH
Prying is fine, as long as you use your hand. Anything else could chip or break it.
Moderator
People's Republic of Colorado
I don't know what the circuit board looks like, but you may be able to fix it by touching up solder joints with some solder that has lead in it.
ReaperHWK
ReaperHWK
Well I replalced it with an aftermarket one that had good reviews, it cost $80. It worked for 2 days and the side detection LED blew out and it also has a slightly different LED matrix pattern than the OEM is my biggest gripe.
Going to return this aftermarket one and get the OEM unit.
Just thought I'd share in case anyone was wondering what the difference was between the $80 aftermarket one and the $250 OEM. Most reviews of the aftermarket don't go into any real details.
1)The LED matrix is different for the blinkers and side detection(you can tell when they light up)
2)The OEM has a better field of view than the aftermarket for the side blinkers (wider azimuth angle)
3)The aftermarket has a slightly different heating element(didn't test it but I can tell by looking at it)
4)The OEM has material on the sides such that when the mirror is fully tilted (left or right), it blocks your view of seeing inside the mirror housing
5)The color temp of the aftermarket is very close, but you can tell a slight difference if you analyze it(Not a huge deal).
6)The OEM has better environmental enclosure for the electronics (epoxy)
Loki223
Elk, WA
Buy a set of escalade mirrors off of ebay and swap those, they make a huge difference for visbility
RST Dana
OH
Fingers on top or outer end. Close your eyes, then pull it!
D Rollins
