Show off your 2015+ leveled Tahoes and Yukons!
Tregs
My '16 Denali XL with Fabtech 4" kit, 20x10 Fuel Tritons and 33x12.5 Fuel Gripper M/T's.
How do you like the 4" fab tech kit? Did it change the road manners? Did you install it? Most of the reviews say that is bolt in, but some say you have to do some cutting.
I've been looking at installing one of these kits.
InTruckDesign
SW CT,
There is some cutting, well more like trimming, mostly to provide clearance for the front diff to drop down. The truck rides like it did stock. Fabtechs way of adjusting the magneride sensors up front is not adequate, but fabbing a bracket up fixes that and re-centers the sensor. I also think they should reduce the rear lift height by 1". With kit installed there is 2" of rake still, not a leveled stance.
Tregs
Thanks for the info. I have an SLT so there's no magneride, but I was trying to avoid cutting. Did you have to trim it so much that you can't go back to stock if desired?
Can you add a leveling kit up from to eliminate the rake?
Thanks for your help.
InTruckDesign
SW CT,
I dom't see why it could not go back to stock. You probably can add to it, but I can't see that as being the smartest thing to do. Best bet would be to swap in a smaller coil spacer in the back.
Tregs
Intruckdesign,
Thanks for your help. Last question. It says you can't use factory wheels. Is it because the modifications drive the need to change the back spacing?
Thanks again
InTruckDesign
SW CT,
I believe it is due to the new uca, I never tried them so not sure if they clear or not. My thinking is my stock 22's would clear, not sure of oem 20's and smaller though.
Denton
Waco, Texas
2.5" SuspensionMaxx leveling kit
285/60/20 Goodyear Duratracs
Tregs
Epic donkey,
That looks great. Which 4" lift are you using?
Bigmac18
lets get this thred going again...I just got a "new to me" 2015 2wd thoe...that is in desperate need of a lift!
WITCH1975
