Sharp Halo projector fog lights by Spyder for Yukon at CARiD.com
carid
Cranbury, NJ
When you are living in a fog-free area, then such an add-on as fog lights may not be useful in your life. However, if you occasionally find yourself in dense fog area where it is quite common to have zero visibility... Well, then probably fog lights could be a huge help.
Fog tends to reflect the light back causing the glare you see when it's really thick. CARiD is here to cover you up with our super bright Halo projector fog lights manufactured by Spyder for improved illumination and better visibility. Mounted low on the vehicle and angled toward the road, fog lights reduce glare and illuminate the road right in front of the ride.
The most important thing about these fog lights is that they come equipped with Halo rings, that light up with your parking light. Moreover, Halo rings circles are really sharp and visible even in a daytime.
Find prices and more details about our bright Halo projector fog lights by Spyder here:
Spyder® - Halo Projector Fog Lights
http://www.carid.com/spyder/halo-projector-fog-lights.html
High-quality fog lights, in addition to good headlights, are still better than headlights alone.
YukonXL04
The Riverboat
Arlington, TX
It would be great for potential buyers if you guys took pictures of the light output so they can see how well they work.
carid
carid
Cranbury, NJ
Hey, folks!
Fog light bulbs output is pretty the same as the one produced by factory bulbs. The halo rings output look something like that, check out the pics. I found them on another forum, so they are provided for the reference only.
i wish someone would come out with a projector fog light for 00-06 tahoes that didn't have a halo ring or those tacky leds on each side of the halo
carid
carid
Cranbury, NJ
If you like the look of these projector fog lights, but hate the glowing halo rings around you can simply leave the halo ring wires unconnected, so they will not come on.
Once you switch on the fog lights - only the actual fog light bulbs inside of the projectors will light up!
+ technically you can make an HID conversion on the base of these projector fogs!
(Replace standard halogen bulbs with high intensity HID ones)
carid
carid
Cranbury, NJ
Yes sure, you can always get a discount on this product, just contact our sales department at 800-505-3274 and our guys will provide it for you!
agmanw8n
