Welcome to the partyChecking in. Same story as the previous hundreds of posts. Service 4wd. Dealer dropping off a loaner in the AM and taking my vehicle for the weekend. Sucks, but kinda expected. Just unde 20,000 miles.
[emoji19]
They do last update on my car last month when I bring for 22,500 miles services after that the grinding noise is going and I think they finally fix is running very good after that.Interesting. I took Yukon into the dealer for oil change service last week and asked about status of the issue. Service manager said still no fix (at least as of Tuesday) and that GM believes that the problem is temperature related. My last update was late January and I mostly remembered to change back to 2WD before shutting off engine.
So either the service department does not have the latest information, an updated fix came out later in the week or it is really temperature related so those of us in the snow regions won't have a problem until next season. I have to take my 2015 Sierra 2500HD in for service tomorrow and ask the service manager to check with GM. No Auto option on that vehicle so no issue last winter.
I've had mine in 3 times for "stuck in 4WD" issues so far, in just under 25K miles. The last time I had it in (Jan 2016, 20,500 miles), they replaced the "TRANSFER CASE TWO/FOUR WHEEL DRIVE ACTUATOR". The time before that (June 2015, 8,500 miles), the performed this update: #14616: Service Update for Inventory and Customer Vehicles - Service 4WDMessage - Transfer Case Stuck in 4WD HI. The first time (Jan 2015, 2,000 miles), the record says this: TRANSFER CASE CONTROL MODULE REPROGRAMMING WITH SPS. I think this was before GM had really diagnosed the problem at all.Is anyone still having problems with this? My 2015 went out at 7500 miles, same as reported here. But I only bought mine 6 months ago! You'd think they would fix this before I drove off the lot!
We all get the same issue, they only reprogram the transfer case and problem solved.I have a 2015 LT Tahoe with 4WD and the heavy duty trailering package (two speed transfer case). Bought it new in August of 2014. I get the "Service 4WD" message regularly. Typically, 3 times a week. When I first got the vehicle, I drove it with the transfer case in "Auto". A couple of times when I started the vehicle, the transfer case was locked in 4WD. Not sure if it was 4WD hi or lo, but it was locked. First time I was near the dealer, so I took it in. Second time I had to have it towed. They reprogrammed it and tried various things. Each time proclaiming it was fixed. Not. The told me I shouldn't use Auto because this would just keep happening. When I get the "Service 4WD" message, the transfer case will not respond to any command. If you move the selector to another setting, the light on the selector goes out. Nothing happens. So, I have an overpriced 2WD vehicle that is lugging around a lot of useless heavy hardware. Can't use the Auto because I might get stuck in 4WD. I can't count on being able to use the 4WD if I need it because if the Service 4WD comes on, I can't switch into or out of 4WD. I called OnStar and asked why their diagnostic reports regularly say my driver train is AOK, when it's clearly not. They argued with me saying it was fine. A supervisor came on and said I should call them from the Tahoe when this Service 4WD message came on so they could do a live diagnostics on the vehicle and that would capture it. So, I did that. Diagnostics said all was while I as looking dead at the Service 4WD message. I said their service was worse than useless, because it is falsely reporting that my drive train has no issue, so their diagnostics contradicts my claim that this happens all the time. They said maybe the OnStar system was broken and I should take the vehicle in to get that checked or replaced. They're so stupid, the don't even know if the transfer case is part of the diagnostics check, but they were willing to say anything to get rid of me, apparently.
Maybe I should join a support group and get over my hatred of Fords.
Wow never heard about transmission replace that is crazy.Hello first time post. Recently purchased 2016 Yukon Denali with 3,900 miles. Now have 6,300 miles and have the "Service 4WD light" and cannot switch out to 2-WD. Normally run in 2-WD but when raining or slick switch to Auto. Had been working without any problems but past weekend after running in rain got the service message. Front wheels lock up when turning sharp left or right and I had to drive over 400 miles back home like this. Took to dealer today and they tried the quick shift to neutral and switch to Auto back to 2-WD but didn't clear so they now have it in the shop.
Shop Manager told me it would be about a week because the transmission guy had to do the repair and he has to replace 5 transmissions before he gets to my vehicle. Great GM transmissions! Not certain if these are in Arcadia or other GMC vehicles but not good. Also having the Air Bag replaced.
