secondary aux fan
Monstar_est87
City of Angeles
The diagram u posted in page 1 that disappeared... And i wish... Sum dumbass broke the solenoid and cut the lines... I just left it... But ill be ur friend :)
SunlitComet
OBS Jedi-Do Good
unknown at this time.
will try it here first let me know if you want pm'd. this is for a '97 tahoe dieseler. i would suggest for on demand use, i would ground the dark blue wire of aux relay and run the positive side of the lead that actually powers the a/c clutch. maybe stick a 1 amp fuse on the aux relay coil lead for safety. other wise do what you can for relaying the aux fan as the provision is not complete for it in the tahoe. we do have those aux 30A **** fuses to use.
Monstar_est87
City of Angeles
:Handshake: sure sort of like ur weed man :mexsmoke: no problem wat parts do u need..? o yea i lost the low speed in the rear as well as the 2 low speeds up front... U told me how 2 take care of the front but wat do u suggest for the rear..?
SunlitComet
OBS Jedi-Do Good
look for volts on dar blue wire on back of rear fan switch when in low speed. for starters. wants pics of diagrams again? could you read last ones i posted?
CKendrick
