Roof Rack for 1996 2-Door Tahoe
DanSchmidt
I'm trying to find a replacement for the flimsy stock crossmembers. Bought a welded steel roof cage, and the weight of that plus the spare tire is compressing the stock crossmembers to the roof. Looking at some on Amazon that will hold 150+ pounds, but none seem to be quite wide enough (interior rail width is 48", outside to outside is closer to 51") Anyone have a recommendation?
exp500
I haven't seen any direct bolt in rack parts such as cross tubes. I have seen expedition baskets that replace the whole thing and can carry some weight.
Otherwise, it will be a build your own. Try searching for Aero tubes- Aerodynamic tubing. You might find something that will work for you. Good luck and report back .
dizhai
