Rocksford Fostgate P1000-1bd AMP
timjohnson22
GEORGIA
I had this Rocksford Fostgate P1000-1bd AMP for 2 months. Nothing is wrong with it. I needed a stronger AMP for the custom setup I am looking for. I am selling this Rockdford Fostgate for $275 or Best Offer + $15 for shipping! Please PM me
AMP DESCRIPTION IS BELOW
P1000-1bd
1000 Watt Class-bd Mono Amplifier
With its super efficient Class-BD circuit topology, the P1000-1bd assures maximum BOOM for your buck! Due to its dedicated low frequency response, this amplifier is optimized for mid-bass speakers or subwoofers only. No need to worry because its 1-ohm capability will drive a pair of 4-ohm DVC subwoofers or quad-configuration of 2-ohm DVC subwoofers with ease.
Description Value
CEA-2006 Compliant Number of Channels 1
Rated Power
(RMS Continuous Power) 250 Watts x 1 @ 4-Ohms
500 Watts x 1 @ 2-Ohms
1000 Watts x 1 @ 1-Ohm
Total Power
(Sum of Rated Power) 1000 Watts
Bridgeable No
Efficiency (average) 86% @ 4-Ohm
84% @ 2-Ohm
76% @ 1-Ohm
Crossover Controls Low-Pass (LP): 35-250Hz 12dB/octave Butterworth
Tone Controls Punch EQ2 Bass: 0dB to +18dB @ 45Hz
Infrasonic Filter: Selectable 12dB/Octave, -3dB @ 28Hz
Signal Input Low level: 1 RCA pair
Signal Output Low level: 1 RCA pair
Power Input Connector Block
Power Wire Gauge 4 AWG
Speaker Output Connector Screw terminal barrier strip
Speaker Wire Gauge 8 AWG to 18 AWG
Heat Sink Type Cast aluminum
Cooling Convection
Remote Controls Optional PEQ Remote Punch EQ
(overrides built-in Punch EQ2)
Visual Indicators Power Thermal Protect
Circuit Topology Class Class bd
Frequency Response 20Hz to 250Hz +/- 1.0dB
griffey_mojo
