Roar pedal success
Chickensandwich
Just purchased the Roar Pedal for my 2021 Tahoe PPV. WOW! The difference is amazing. The acceleration quick and smooth. I have one on my Mercedes as well, but this truck really needed it. It was simple to plug in and no set up needed. The small remote that comes with it is fine for on-the-fly changes, but the app is my preference. Set it and forget it. $159 on Amazon..worth every penny!
KMeloney
Did you look into the Pedal Monster and/or Pedal Commander when looking into the Roar Pedal? (I hadn't heard of the RP before your post.)
Chickensandwich
Chickensandwich
Pedal commander has issues from what I read. I don’t know about the pedal monster, but I have another Roar pedal and it works great. I love the app too. The small Bluetooth box it comes with to change the settings is kinda garbage, but usually just set it to one setting.
fondupot
South Carolina
Looks to be similar to the Soler DLX Throttle Controller. Although I prefer the look of the controller module on the Soler. I've had it installed on my 2021 Yukon 5.3 for several months. Helps with throttle lag. Pretty much a set it and forget it. I don't mess with the settings very often.
Chickensandwich
Chickensandwich
It does look similar. The controller for the Roar Pedal is bluetooth as well as the app, so mounting it would be cleaner, but I dont use the controller, only the app. They are all probably very similar. I just went with what I know works well.
fondupot
South Carolina
The Soler unit also has bluetooth and an app. The controller can be mounted in a hidden spot under the dash and controlled entirely from your phone if someone wanted.
