Road Noise
vicnation
I recently purchased a 2006 Yukon Denali XL with 175K miles. I don't think too much has been done to the truck other than general maintenance. I'm hearing and feeling some road noise that feels like friction in the front end when going highway speeds. It has a low-pitched roaring sound.
On a typical import, I would find a parking lot and drive around in circles, putting a load on each wheel hub. In adition, when accelerating in an import with bad hub bearings, the noise gets louder the faster you drive. In the Yukon, it doesn't seem to work that way. How do I tell if my hub bearings are going bad? Is there anything else that could make that noise? The tires are new and definitely not the cause of the noise. I've rotated them just to verify.
MassHoe04
Western MA
Get it up on jack stands and give it the old look, listen, feel test.
Could be hubs...
Do the wheels feel like they are bound up?
Push/pull/rock the wheels up/down and side to side... Is there too much play?
Do you hear any noises when spinning the wheels by hand (chirp, grind, squeak)?
Could be brakes...
Calipers aren't locking up on you are they?
How do the pads, rotors and calipers look (newer or all crusty)?
Are rotors smooth or scored?
Pads good or are they worn down to metal?
Do you feel dragging or hear sounds like metal or rocks on steel?
I would probably bet more money on brakes than the hub. Mileage isn't crazy high.
Let us know what you find. Photos of some stuff might help.
Good luck!
V
vicnation
When I rotated the tires, I got a good look at the brakes. The fronts are almost new. The rotors are probably original and a little dished but there is no vibration when braking. I don't expect the Yukon to brake as well as my small pickup and it definitely doesn't. But I don't see anything wrong with the brakes other than a leak around the hydoboost/master cylinder area. Being from the south, this vehicle is completely rust-free. I didn't remove the calipers so I'm not sure if the slides are stuck or not.
With the Yukon in the air, I did spin the tires and just felt what I would consider typical drag because of the AWD. I didn't hear anything like metal-to-metal or grinding/squeeling noises.
But this vehicle is new to me so I'm not exactly sure what is normal or not.
wjburken
Eastern Iowa
Based on what you are sharing, keeping in mind the fact that I am more than 100 miles away and can't see, hear or feel what you are, my money would be on a wheel bearing. You have 175K and 15 years on those wheel bearings so it would not be at all surprising that one is giving up the ghost. If you change one, I would do both.
If you can get the front wheels up off the ground again, I would grab the wheel at the 12:00 and 6:00 position and see how much play there is or if you hear a clunk when you to it. Spinning the wheel may not tell you much since you don't have the bearing loaded.
jack up the front wheels and grab them at 12 & 6 and wiggle them in & out if there is any movement/play then it's the hubs, you can wiggle them at 9 & 3 but there will be some play there because of the steering but it shouldn't be excessive.
also spin the wheels forward and backward and listen, it should be pretty much dead silent if you hear any ticking/clicking/grinding that is also the hubs (or brake pad) but the pads should not be rubbing.
other than that get a flashlight and get under it and just look, look at the axles, diff, drivelines, etc any leaking fluid or grease coming out is a tell tale sign of a potential problem. check the front diff fluid level. it should be level with the fill hole, remove the filler hole bolt and finger it. :hump:
rockola1971
Indiana (formerly IL)
Growling in the front is typically a hub getting ready to throw up on you. 175k on original...be prepared to do both and while I had them out I would toss in new CV halfshafts and be done with it. Be sure to properly torque the axle nuts to the correct value!
MassHoe04
Western MA
OK. So my betting instincts might be wrong on brakes, but I'll revert to the first of the two possible causes mentioned in my earlier post... Strong possibility it is a hub.
As @Doubeleive hinted at, issues with CV on front drive shafts could also feel and sound weird. Especially, if boots ripped water got in or grease got out...
The CV joints grinding dry can feel like they are binding and make noises. Good inspection on the front shafts might identify an issue or eliminate them as a possibility.
same if the front diff fluid is low or empty......could be a box of glitter
S33k3r
Dallas, Texas
If you aren't used to AWD, that may also be what you are experiencing. We have a Sierra Denali with AWD. You might just visually inspect the transfer case.
V
vicnation
I checked everything out last night. Doubeleive might have nailed it. The shafts and boots look fine. There are no leaks anywhere. I looked for play in the hubs and didn't find any. I drained the front differential fluid and that was a problem. Doubeleive used the term glitter and that seems to fit. The magnet had a nice beard too. I filled the differential with new 75W-90 and drove it and much of the noise/feel that I thought was excessive was now gone. Looks like I may have a new front differential in my future. I've got to check the rear fluid next because now I'm sure that was never changed.
D -money
I now have the same sound in my 05 hoe. It starts around 27-30 mph and shows back up around 55. Intermittant, about 6-8 s seconds. Dissapears if i gas it or jerk wheel to right or left. My first thought was hubs, so im going to check play when i do tire rotation after xmas. Is there any gotchas behind normal hub removal on my rig, im a ex ford guy. Thanks for everyone on site and the invaluable forum.
MassHoe04
Western MA
Buy one set of new hub bolts. On the first hub, back the old bolts out about a half inch or so. You can beat on the heads of those old bolts with a 3 lb. hammer and the hub will pop right out for you.
No torch needed (usually).
If you have to do the other side too, remove all three of the original bolts completely and thread the old beater bolts in by hand and leave them sticking out about a half inch or so (like before). Use them to beat that hub out and save them in the basement for future hub replacements.
That way, you will install the one new set of bolts; be able to use three of the good original bolts and have the beater bolts for use as a "tool" should you have to do hubs again (you won't need to buy new bolts every time).
Also, use a breaker bar to remove the hub bolts if you have never done them or have no idea if they have ever been removed.
Avoid the temptation to rip 'em out with the impact wrench. You might snap them. (At least you would have that new set of bolts on hand, but you wouldn't be able to use the old ones to beat the hub out on the other side...)
Wouldn't hurt to try soaking the bolts with a good penetrating oil too. Not sure it will actually soak all the way in, but wouldn't hurt.
It's early and I haven't finished my first (of several) coffee yet. So, if you need clarification on this morning ramble... Just let me know.
SnowDrifter
Sasquatch Country
Make a new thread, tag me in it, and I'll walk ya through what you need to know :)
D -money
Thank you for your tip, so cool to have help when one never has.
. Im going to give it hell if thats what the noise is and will post the outcome. Fortunately i have 2 vehicles if i get stuck. Peaceful holidays.
1948Buickroadie
