ridin_low07's 02 Yukon XL Build
ridin_low07
ridin_low07
Okc
Pulled my driver door harness to find the power window short. Found it. Fixed it. Now the door ajar switch isnt working lol. Guess I get to pull it again lol.
ridin_low07
ridin_low07
Okc
Got the drop kit installed, free travel mod done, and alignment knocked out. Going to give the rear springs time to settle before I decide if I am going any lower. It feels a lot more planted now. A lot less body roll around corners.
Did you measure before and after to keep track of actual droppage?
Oh- those wheels suck...
... to make them. :D
img_3100-jpg.222561
img_4935-jpg.235370
ridin_low07
ridin_low07
Okc
img_3100-jpg.222561
img_4935-jpg.235370
Top is before drop bottom is after. Upper numbers are fronts lower numbers are rear. I need to strip the paint off my wheels and redo them in a bad way.
ridin_low07
ridin_low07
Okc
Need to find an extended upper control arm to get my camber adjusted back out.
ridin_low07
ridin_low07
Okc
I'm not that familiar with the GMT800s... can't you just use the Belltech alignment cam plates like on the GMT900s?
I havent looked into anything yet. Just seemed like they might be a thing lol.
There's some Belltech alignment cams for sale in the classifieds. If those aren't enough, you're gonna need offset bushings. I never knew there were any extended UCAs.
Ill look into that. Thanks man
Conedaddy
