ride problems
dirtbikedale
I have a 99 yukon with a 2 in. leveling kit with 285/70/16 toyo a/t and pro comp shocks. My problem is when I go over bumps i hear a clacking in the rear? also can i put bilstien hd shocks even with a 2 in. leveling kit? I feel alot of tire hop in these ****** south jersey roads. I replace the left idler arm but what bushings should i replace? and i wanna go with energy suspension.
thanks
retorq
Kingman AZ
All of them!! I did upper and lower control arm bushings, sway bar end links and tie rod and ball joint boots. Still have to do the main sway bar bushings. Also check your pitman arm while you are there, they are a wear item and if you changed your idelr arm due to wear the other side is probably as bad.
Drewphil
