Replacing Tie Rods and Ball Joints Question
Justinj360
Senior Member
I'm new to tie rods and ball joints so this might be a stupid question. My 2004 Yukon needs new ball joints and tie rods so I'm wondering if they all need to be replaced at the same time or if I can change the tie rods first and then replace the ball joints later down the road. Would that cause extra wear on the new tie rods somehow? Seems like if the ball joints can't keep the wheels from wobbling and being perfectly straight then that would be bad for the tie rods.
jaywoo65
Cabot, AR
I'd do it all at once since you're going to have to do an alignment anyway. Better just one than two. Might think about the pitman arm and idler arm while you're doing the rest.
Justinj360
Justinj360
Senior Member
So does it need to be aligned after you replace the pitman and idler arms?
jaywoo65
Cabot, AR
Couldn't hurt but i don't think you would absolutely have to. Might depend on how worn the arms were.
Danzigman
Galveston, TX
I just replaced the tierods (inner and outer) , pitman, idler and idler bracket. You will need a front end alignment afterwards.
Justinj360
Justinj360
Senior Member
What if you were just doing the pitman and idler arms and the idler bracket? Would it need an alignment for just those parts?
Danzigman
Galveston, TX
If you are sure to hold the steering wheel in place you should be ok, but everything I read says that you need to align afterwards.
shreksbrother
Auburn Hills, MI
Just a suggestion (if you are in the US) so you do not have to debate whether or not to get an alignment... Firestone offers a lifetime alignment. Any time I do suspension work it goes in for an alignment and costs me nothing. I think it was $199, and was money well spent.
Sears offers one, too, but buyer beware! If you read the small print, any suspension work done on the vehicle must be done by them or they will cancel the lifetime alignment. It happened to me! :mad:
Justinj360
Justinj360
Senior Member
I haven't heard of that before. I'll definitely have to check into it! That would've saved me a lot of money already. Wait Sears works on vehicles?
shreksbrother
Auburn Hills, MI
If you plan on keeping your vehicle, it is totally worth it. Two alignments and has paid for itself. The guy at Firestone told me I could come daily if I want. Obviously I do not do that (although they do have good coffee!), but anytime I raise/lower my Yukon, feel a slight vibration, or if its in there for new tires, it gets an alignment.
JasonW4141
