MattysHoe95
- Joined
- Apr 28, 2017
- Posts
- 23
- Reaction score
- 17
This HVAC system in this truck has been a nightmare from day 1. I used to be able to give it a charge a few times during the summer and it was fine. Each year it degraded until finally the charge was leaking right out somewhere. No matter how much dye and nights with a black light I never found it. This year before summer starts I decided to replace everything. Evaporator, Compressor, Condenser, All lines, The accumulator etc. I even added an Aux electric fan. All parts are aftermarket. Condenser is half as thick. Charged it up and Even though i can feel the liquid going through the expansion line into the evap and I can feel the heat coming from the discharge of the compressor and condenser , I cannot get air temp from the vent below 60 while driving. I need to get new adapters for my gauges to hook up and check high and low side so for now all i can go by is the dummy gauge on the refrigerant can. I also have access to the evap from a hole I cut to remove it and then covered it up with the cutout and some tape. I even checked the evap while running and it is not getting any frost, No water drip from the drain pan. This is driving me nuts. All this work for it to work the same as the old parts..Very frustrating to say the least.
