Rear windows won’t go down.
a4edwin
ny
07 Denali xl my rear door windows will not go down from their respective switches but they will go down if I do it from the front. Can it be both switches are bad on either side or can it be the drivers switch? I’ve checked the window lock switch and I still have the problem.
exp500
Could even be the BCM. You could try swapping relays in underhood box (3).
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
There is a bypass in the rear door jamb too on the door latch, Check that too,
A
a4edwin
ny
Only thing I’ve seen at the door latch is the child safety locks nothing else. I’ll check under hood tomorrow it’s raining like crazy here.
Mohq
