No speedometer, front windows, heated seats, locks.
Nacknic
Need help DIAG a problem 2005 suburban LT 4x4 heated seats, non-flex fuel, dual climate.
Bought this for 1k now runs and drives new trans, had electrical problem but it was just a grounded positive wire. Got rear windows to work, wipers work, turn signals work. Rear windows go up and down but only on back switches there IS power going to the window switches. Radio works.
Front windows won’t roll up, dash doesn’t work, PSI, temps, speedometer, RPM. RPM and speedometer maxed out no matter what. Heated seats dont work. Trans shifts, car moves. AUTEL scanner can’t communicate with anything. ECU, BCM, everything. Replaced BCM, nothing changed. Checked fuses, everything works. Changed door switches, nothing.Re
Welcome to the Forum from NH.
Pics of the truck, please.
Whenever we see multiple electrical issues at a time, we first check the battery health (bench load test at a parts store that has one), battery cables and battery connections (these cables generally rot from the inside out), all ground connections within the engine bay (clean and tight), and the major ground connection on the frame underneath the truck, approximately below the driver's foot. After that, we go through the actual fuse-by-fuse examination for both major fuse boxes.
Just so that we are all in synch, have you performed/verified all of the above? If not, please do.
You state that you replaced the BCM. Did you program it to your vehicle, afterward, (or have the seller program it to your truck's VIN before shipping it to you) as it is a required step? I'm thinking no, as you cannot get your bi-directional scanner to connect to the truck's systems.
Regarding your scanner's inability to connect with your truck's systems, Dr. Google suggests the following:
Your bi-directional scanner likely won't communicate with your GM SUV due to a problem with the vehicle's electrical system, such as a blown fuse for the OBD-II port, a bad connection at the OBD-II port, low battery voltage, or a wiring issue. To troubleshoot, check for a blown fuse, inspect the OBD-II port for damage, ensure your battery is stable, and try a simple ECU reset by disconnecting the battery.
Initial checks
  • Check the fuse: Look for the fuse that powers the OBD-II port (often shared with the cigarette lighter) and check if it's blown. A blown fuse will need to be replaced.
  • Inspect the OBD-II port: Look inside the port for any bent or broken pins, or signs of corrosion. Make sure the connection is clean.
  • Check battery voltage: Low battery voltage can disrupt communication. Make sure your SUV's battery is in good condition and fully charged.
  • Update scanner software: Ensure your scanner has the latest firmware and is compatible with your vehicle's specific protocol. Some newer GM vehicles may require specific software or tool capabilities.
Resetting the vehicle's computer
https://www.youtube.com/watch?v=xSF59iBXLdk&t=127
  • Disconnect the battery: Disconnect both terminals of the vehicle's battery for at least 10 minutes.
  • Press the brake pedal: While the battery is disconnected, press the brake pedal to help discharge any residual power in the system.
  • Reconnect the battery: Reconnect the battery terminals.
  • Try again: Turn the ignition to the "on" position (without starting the engine) and try communicating with the scanner again.
If the problem persists
  • Disconnect potential parasitic draws: If a component like a stereo is drawing too much current, it can prevent communication. Try disconnecting the fuse for accessories to see if communication is restored.
  • Test with a different tool: If possible, use a different scan tool to rule out a problem with your own tool.
  • Seek professional help: If none of these steps work, the problem may be a more complex wiring issue or a faulty Electronic Control Unit (ECU). In this case, professional diagnostics will be necessary.
Let us know how this works out for you, after checking out the above.
Nozbich
Check if you’re getting speed when hooked to a OBD-II scanner and driving.
Nuclearseal
Gauges not working is the cluster, a known issue. Had the same issue, replaced cluster with a rebuilt one, all fixed.
I had the issue with scanner not communicating (Autel scanner as well). something to try, may not do anything but my issue was the ABS module. Simply unplug the ABS module (underneath driver side on the rail, easy to get to), then hook the scanner back up. If it communicates, the ABS module is bad. Can try unplugging other modules as well. I likened it to a conference call, if every one is talking in turn, no issue communicating, but if you get that one ******* screaming overtop of everyone (in my case the ABS) nobody else can communicate. (I had tried computer reset multiple times, looked for grounds loose, etc... Found an old post on an old message board that mentioned the ABS module and boom that was my issue)
spectol
