Rear window not working
Matahoe
Grand Rapids, Michigan
My driver's side rear window won't roll down anymore. I can hear the relay activate back at the door but no roll down. Either motor or sticking window because power is getting back there. Just wondering if anyone has any experience and can provide a quick solution? I would rather not have to take the trim off the door but I can if need be.
I'm reasonably sure that you will need to remove the trim from the interior of the door, in order to do any meaningful troubleshooting.
latvius
Ariton Alabama
My money is on a new window motor, it's not hard to do. Get the suction cup tool to hold the window up and when you remove the door panel you need to pull up once you have all the screws out.
TahoeDan
This video helped me replace my rear window regulator assembly.
You may also want to clean and lube all your windows to prevent further problems.
X-ray Nerd
