Rear wheel play in and out - source of clunk?
Erickk120
you'd expect play when the brakes are off the rotor though, I would imagine with the brakes still attached there shouldn't be any excessive play to form a clunk, hard to measure end play in the video, I will jack mine up tomorrow just to make sure am not going insane, I'll update.
treehan77
treehan77
TYF Fiend
Crestview, FL
Give us a detailed rundown how how you replicate the noise, general apparent location, and both what you've checked and HOW you checked it
Noise can be replicated by making a sweeping turn after turning the opposite way. Lug nuts are tight. DEaler mechanic heard it on test drive. He put it on lift and used pry at etc to check ball joints, related suspension parts etc. he basically said do t worry about, it’s probably just a stabilizer bushing starting to go. Drive it till it is really bad lol. I did this myself as well, couldn’t really say bushings or stabilizer links are visibly shot, but those are cheap so...
Chris2144
Just about every 1500 nbs is 140. Think the only one that's not is the 1500 HD.
OP I still think you have a problem in your diff. Sway bar mounts don't make noise when you pull and push on the tire in and out. Pull the cover off and have a look. Also have someone pull and push while you see what it is. You don't want to loose an axle going down the road trust me it's not a fun time.
treehan77
treehan77
TYF Fiend
Crestview, FL
I asked the mechanic if he thought it could be the diff before he inspected it. I can only assume he knows what he’s doing. Hopefully the stabilizer bushings and links I’m going to replace will cure the noise I hear when driving, and this amount of play is normal. Fingers crossed
treehan77
treehan77
TYF Fiend
Crestview, FL
I figure the bushings and links are cheap and a good chance they will fix the clunk. If not, I’m sure replacing them at 187k will tighten things up a bit anyway- they’ve gone through a lot. Dont know what else I can do, I went to the dealer for diagnostic. I guess I’ll try them again if it doesnt fix it. I will install the bushings and links myself. Pretty cheap whack at it.
Chris2144
Well you said that the noise you hear in the video is the same noise you hear while driving. I would think that you have Isolated it just need to figure out why it's making the noise
Pepper1700
