wow..
I don't know where to start
I can't even accurately judge the difference because for starters my speedo is off big time
I'll probably have to grab one of my buddy's to see how much its off before I can even start my review
the ABS light is now on and it says service brake system so I don't know if that has anything to do with the gears
and it looks like its already sucking away my gas
the only positive is about half throttle it rips
I'm excited to see what full throttle from a dead stop will be like
The abs light is on because you're effectively outside of stock parameters on the abs tone ring in the rear differential, the pcm needs to be corrected with the proper value or it will throw a code because it thinks it is spinning at xxrpm when it is really going at yyrpm due to the gear ratio variance. No big deal you won't damage anything you just need a retune to adjust the parameters and the light will cease to illuminate.
