Rear bumpstops
protonvx
It seems like I bottom out on the rear bumstops frequently. I installed the Belltech ones when I did the drop. If I remember right, they stick out of from the frame maybe 1" or 3/4".
Any sugestions?
NORCAL SS
SUV SUSPENSION GURU
cut the rear bumpstop brakcet off takes 5 minutes to do and you will gain over 3 inches more clearance.
P
protonvx
What do you use to cut it with? I sold my plasma cutter a while back. Sawsaw or cutoff wheel?
NORCAL SS
SUV SUSPENSION GURU
8 inch sawzall blade and cut along the frame and serioulsy 5 minutes
P
protonvx
Thanks. I will give it a try, hopefully this weekend.
crazycrew
Vacherie, LA
Tony, I think I need to do this too.
Dumb ? But do you have a before and after pic of the bracket. Like one factory and one after it's removed?
crazycrew
Vacherie, LA
Thanks Tony. That's exacty what I wanted to see. I thought it was that long one and not just where the stop squeezes into
P
protonvx
Done. It rides much better now. Thanks for all the advise.
crazycrew
Vacherie, LA
Took care of mine also.
Used a plasma on the drivers side!!! In the 15 miles I drove home from my friends house that did it was all good to me.
The hadn't said anything yet, so I guess it's good.
Gonna get with you soon on that panhard bar Tony.
CKendrick
