Rear Brakes
the blur
Cyber Space
What's with the rear brakes on these trucks ?
New pads, new rotors, and within 20,000 miles, the pads loose full contact. The rotor starts rusting, and now only partial pad contact.
This has been on every GM SUV I owned.
petethepug
Michael
SoCal
2nd on the guide pins need lube and new boots. Not saying that’s it, but it has those symptoms. Do you run the anti rattle clips on the mount ears of the pads?
PPV12HOE
NC
Check your guide pins and make sure they move freely and also make sure your pad hardware is in good shape...
Wolfbraid
Winston Salem, NC
Also make sure your pads are on correctly, there is an inside and outside pad. Whoever had done mine previously(before I owned it) put them on incorrectly, Shape wise they fit, but there are rivets on the backside that hit the piston(if it's on the wrong side)
FrankU
Babylon New York
Funny (NOT) I had the same problem. I bought the Tahoe used from a Chevrolet dealer that did the brakes too.
Wolfbraid
Winston Salem, NC
Oh it killed me, I couldn't for the life of me figure out why I couldn't get the caliper back on, finally just took a break and went to watch youtube videos, and sure enough apparently this is a common error
Big Mama
Virginia
There’s something to be said for wisdom. That’s what my kids call my grey hair.
GMT800 2005 Tahoe Z71
Navy Supporting Member
Nothing was mentioned about the quality of pads, hardware and rotors used. Then there is the chance of wrong pads install for inner and outer pads. Nothing mentioned about brake install procedure, how much cleaning and lubing went on. Plus, you said "This has been on every GM SUV I owned." Are you installing the parts or is a shop or dealer installing. That may well be the one common denominator. Plus, where are you located? Salt on the roads?
T
the blur
Cyber Space
This particular truck, the rear brakes were done by the dealer. I brought it off a used car lot at a Caddy dealer, and part of the deal was all new pads / rotors. One can only assume they are ac delco parts.
vsaravia
