Rear brake question
ktmhans
Connecticut
Hello, changed the pads and rotors on my 04 tahoe about a year and a half ago. All 4 used R1 rotors drill and slotted. And some ceramic pads. Rears started making a metallic noise a month ago. Like the pads were metal vs metal. Wtf can't be that. Today it finally warmed up enough for me to pull it apart. Hollycow the inside pads were gone. Rotors ******. There's even like metallic filled in the drilled and slots on the outside pad. Both sides are in similar shape although the right is worse, I can hear the left although I didn't pull it apart yet.
I don't know what the deal is, I cleaned and lubed everything, made sure the pads freely in the caliper bracket. The previous pads and rotors were nice and evenly worn, 120k stock stuff. It doesn't seem like a caliper was sticking. Is there any think I could be missing. I don't want to do this again. I only put maybe 10k on the new brakes. Front look mint still. As I would expect.
I have something in mind but would like to hear what ya got!
treehan77
TYF Fiend
Crestview, FL
wow usually the rear wear slowly. are you sure the fronts are doing anything? you'd think they'd be wearing faster than the rear, unless the rear is doing all your stopping!
SLCHOE
ASE Master Certified + (L1)
Midvale, Utah
What did you lube the slide pins with?
glazar
