Random NBS / LS parts from my build
Matthew Jeschke
Sahuarita, Arizona
I have replaced most everything on my truck. Many parts I pulled were good or I ended up with extras from the junkyard. I want to pass this stuff on as it's rapidly accumulating in my garage and I hate to throw it away.
I am putting photos on google below:
All parts are turn key with two exeptions...
If you want the starter it only has 10,000 miles on it but the soilenoid shorted to the case, I need to replace it. They are only like $15 to replace but I didn't have the special tool which I can get at the parts store.
Two sets of rocker arms (one partially polished and rebuild but bronze bushings wore out) one set of guide plates. Both sets need retuilt I recommend Che Performance / or Manton trunnion rebuild kit. The one I got doesn't last long, it's also the one summit sells.
Rebuild 3 bolt valve housing gearbox. I got one of the seals backwards. I just need to open it back up and put it the right way. It's the seal at bottom of pitman shaft. Everything is freshly rebuild and perfect shape! I got at juinkyard refreshed and realized I have the 4 bolt housing so didn't use it.
Pressure plate is factory, one spot looks like starter tooth nicked it but works perfectly. No issues otherwise. I removed and put a SFI one on.
Remaining suspension parts were removed I replaced everything new. These parts were inspected and fine though.
Brakes are dual piston off a 2001 Tahoe. I blew up my rear end and got another 10 bolt from the junkyard. These were brakes on that 10 bolt. I reused my old stuff.
May have other parts to get rid of... My attic is full of stuff.
vdesolution
