Radio wiring ?
bigbflex
Just installed an aftermarket radio using a wire harness and now the lights for my hvac controls and my headlight switch dont work. Any ideas or wiring diagrams would be helpful.
Thanks
Diller
Cedarburg, WI
Thanks
And more importantly, we need to know what year your truck is. Helps us help you! :emotions122:
B
bigbflex
Sorry....97
Also noticed my power mirrors and horn dont work. They could have been out for awhile though, I dont use them that much.
el_flores
If your HVAC controls have an exposed circuit board behind it, you might have a problem. Alot of times the antenna will touch that circuit board and short it out causing all kinds of problems. Can't remember if the 97 has those old controls, but if it does, that'll be the root of the problem.
B
bigbflex
Fuses are good, I'll check for the open circuit board.
---------- Post added at 04:41 PM ---------- Previous post was at 04:03 PM ----------
Sure enough, open circuit board. Every light bulb was blown. Replaced and covered the top of the bard with electrical tape.
Thanks guys
el_flores
Next time you take out your radio for whatever reason, make sure and wrap the antenna with tape. That's the best way to prevent this. Glad you got it figured out.
B
bigbflex
I should probably get a dash kit too. Instead of just letting my radio bounce around in the dash. lol
Thanks again for your help, I would have never thought that could happen. I was about to rip the dash apart.
briannorris
