Radio dim not going back to "day mode"
KBones
When turning off the headlights, either manually or automatically, the led's in the radio should brighten back up and return to day mode. This truck I'm working on stays dim (night mode) at all times and is hard to read when the sun is out. Anyone run into this issue? Fixes? I'm leaning toward a new headlight switch...
Did you check the BCM for codes? When my daughter killed the battery and as soon as we got it jumped, the lights were too bright and set a code for such. A lot of codes set but I just cleared them all.
No codes.
You could try disconnecting the battery for a time and see if it returns or swap the light switch out. Was that you or did someone else recently mention the same issue? The navigation unit has a setting in the menu but not sure about the radios.
Big Mama
Virginia
It was a different post. Sounds goofy but check the sensor on the dash. If it thinks it’s dark it stays dark. Shine a light on it
KBones
KBones
Thanks guys. I hate to throw parts at it but I have a switch and the ambient light sensor on its way. I'll install them one a time and test it to find the culprit and just return the one I won't need.
dnt1010
Tennessee
Have you tried the submenu procedure to reset the head unit? I recently had my battery disconnected and my time display disappeared. I had to use the procedure to reset it. Worked great you just have to resist making other changes while in there, it has a lot of options and it looks like you could mess the system up if not careful...................................
KBones
KBones
I have a feeling it's gonna be the switch or the senor on the dash because the led's for the temp on the hvac controls go along with the radio dimming.
Justinj360
Senior Member
Mine will stay dim if just the fog lights are on. That's for a 2004 though. Did you check that?
KBones
KBones
Yup. The radio/hvac lights are staying dim whether the the headlights/fog lights/parking lights are on or off. They should brighten up when the exterior lights are off.
Justinj360
Senior Member
Alright, just checking.
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
Mine randomly does the same thing but it seems to happen when the alternator drops it's charge lower.
BG1988
just override it and set the setting to brightest it's really nice I like how it lights up the whole suv inside.. I want people to know I have premium trim
KBones
KBones
Huh??
BG1988
it has setting to set it to highest brightness even at night you have to poke around to get to the display settings menu
it has manual and automatic settings..
Durobans
