quick question
magnahoe
MA
Anyone know what the annoying squeak coming from the rear of my tahoe is? It isn't U joints their brand new, also not the rear hatch since I have barn doors. thanx
destroyer1362
A work in progress
Midlothian, TX
Leaf springs maybe? Does it happen when you take off from a stop? If so mine does it too and I'm still trying to figure it out, if its not the leaf springs.
M
magnahoe
MA
It does it when i slow down most of the time, also over bumps some times so thats what I was also thinking. I have to replace mine anyway because half of two are missing on my passenger side.
M
magnahoe
MA
Probably the shocks and/or the shock bushings
nope their also new, but keep the suggestions coming. Possibly sway bar end links?
Also anyone know how to stop the lose change sound in the dash? It seems like every piece of plastic in my truck rattles when i go over bumps, but I didn't buy it for the interior.
grimm
Bay Area, CA
Unfortunately, the rattles will come with the territory (more often than not anyways). My interior is completely intact, in pretty good shape too, but my cup holders in the dash will rattle, the sliding cover on the front of my center console rattles, and the ash-tray will rattle.
I also hear squeaks when going over speed bumps or just generally bumpy roads, but that part will be taken care of soon, as I'll be replacing a bunch of suspension components. Just too bad I don't have the extra cash to get my suspension lift while I'm at it.
retorq
Kingman AZ
My rear hatch doesn't line up right and every now and then the rear window will "pop" and squeak ...
GMCYukalade
NC
Theres a grease you can take and put in-between the leafs in the leaf pack susposed to stop the squeak
gulleyman
TX.
Check the spare tire and tire tools. Mine used to squeek but I tightened the spare tire down and put some gloves between the tire tool and the jack....no more squeek :)
wicked2000
El paso TX
Mine was the driver side leaf spring. I tighten up the bolts that hold the lift blocks then i sprayed the leaf springs with W-d40. There are some plastic brackets with a metal around it that hold leafs together. Concentrate on those when spraying it because the noise I think is the plastic rubbing on metal.
M
magnahoe
MA
yeah I just put in new used leafs on the passenger side, which I thought the squeak was coming from and it didn't stop. Oh yeah and I was kinda pissed I had to drive really far to get u bolts, NO ONE on Cape Cod stocks them not even the Chevy dealers.
97yukon
baton rouge
i have the same problem and i bet thats what it is...im gunna check on that tomorrow.
TheBeast99
shit, if my honking is from that damn spare i'm gonna tighten that sucker down SO hard.
then again, mine's a 4door, so i'm skeptical that that's what my problem is....
Hodmjstone
