Quick autoride shock question
pwtr02ss
Tennessee
I have replaced the front struts, rear shocks (all OEM replacements), and the compressor assembly with the Dorman unit. Lately I have noticed that the rear of the truck seems sloppy and I can't really understand why. All of the components have under 10k miles on them. Yesterday I was looking at my dads 2012 avalanche and his rear shocks have air in them, swelling the "bag" part out all of the time. My shocks look like they are deflated all of the time. The compressor kicks on and runs almost every time I start the truck. I have checked for leaks and have not found any at the fittings.
My question is, do they shocks always have air in them, swelling the bag out? Again, mine look deflated and vacuum sealed to the shape of the shock.
Do the lines crack inside the harness and leak there? Its almost as iff my shocks aren't getting any air at all. I haven't towed anything or put anything in the bed to see if it actually airs up so I can't confirm that and I don't really have anything heavy I could put in the bed to test it.
Truck is 08 avalanche LTZ
08grey
I have seen a line go bad before and had a pin hole in the hose. You are definitely loosing air somewhere. Check that the ride height sensors are free by popping off a rod. They should spring up. If they don't lubricate them and loosen them up with your hand.
pwtr02ss
pwtr02ss
Tennessee
How does that rod come off? Also, does anyone make a new line kit?
08grey
Lines are dealer. The rod just pops off with a plier
08grey
Sorry i don't have the part number but the line to the shock was like $50 i believe
pwtr02ss
pwtr02ss
Tennessee
I called my dealer and they show "nothing" for airlines. Not a big surprise
pwtr02ss
pwtr02ss
Tennessee
Bought the line kit from Amazon. That was my problem. The line running to the passenger side was leaking somewhere. It is a touch shorter but I just routed it outside the harness and it was fine. All is good now.
Jonah52
Senor ******
Cleveland
If I were you I would pull the autoride fuse until you find the leak. Your compressor is running all the time most likely and that will kill it. Also, it is normal to hear the compressor kick on each time you start the vehicle.
To test if they are pumping up just have someone stand on the back bumper and either listen for a leak, or watch them fill up. then go from there.
pwtr02ss
pwtr02ss
Tennessee
The compressor, shocks, and struts are new. I have already got it replaced under warranty because I figured it was worn out by now. I installed the new one last night, along with the new line. I just learned of the leak and got it fixed.
cdhpc2
