Question about aftermarket Nav and Adapters
IncisionInd
I am sort of wondering what adapters I am going to need when i install my AVIC-Z110BT. I know that i am going to have to have a standard wire harness, GM adapter harness, steering control adapter.
I am also going to want to install an ipod cable and the MSN direct service.
People are telling me i need an OnStar adapter and an antenna adapter. I dont want onstar and i dont know anything about the other one. Any help is appreciated.
Thanks.
1sikyukon
SFV, CA
IF you dont want your onstar you dont need it. BUT if you ever change ur mind you will need the onstar adapater....everything else u said is correct and also you will need bluetooth adapter if yo get bluetooth
I
IncisionInd
Well for this one the bluetooth is built in.
Will i actually need the antenna adapter. Also does anyone know of a good double din dash kit.
I
IncisionInd
am i seeing that wrong or is that a single din slot for a double din opening. The dash kit that i am going to need is going to need to accomodate a big 7" screen, it need so be a full double din.
Modded
That Guy
Yeah bro its for single and double DINs. The optional slot is meant for those running single DINs, while the normal whole setup w/o the slot is for the DD.
JamesinAbilene
