Question...
Are you certain that the front struts were changed to NON-Autoride struts?
Also, just for clarification, the Autoride struts and shocks are electronically dampened. This is the Z55 RPO code.
The Auto leveling rear suspension, which is RPO G69, is where the air pump comes into play and technically has nothing to do with the Z55 Autoride package aside from the fact that the rear shocks are both electronically dampened (Z55) AND air adjustable (G69). In other words the air pump has no effect on the front struts in any way, shape, or form.
The reason for my first question is that just because someone may have swapped out the rear shocks for non electronically dampened (dumb shocks) shocks DOES NOT necessarily mean they swapped out the front struts.
The air pump and air bladders in the G69 Auto leveling rear suspension are the two areas that fail most frequently. When they do a lot of people see the price tag on the Z55 rear shocks and opt to buy the cheap "dumb shocks" to save money.
If I were you I would check the tops of your front struts and see if they have a plug on the top of them where the strut rod comes up through the center. If they do then you still have the Z55 struts intact up front.
As far as getting the "Service Suspension System" light to go off... that can be accomplished for about $20 and a few minutes to install some 3.9 Ohm 25W resistors at each corner of the truck.
At that point you could go with any shock/strut of your liking and no more error messages on the DIC.
If you want stiffer/better handling you could go with the Tahoe PPV shocks/struts.
I have the Rancho 9 way adjustable struts on the front of my 4/6 dropped Burb and I like them pretty well.
The options are endless.
Sorry for writing a book...
Hope this helps.
