Proper Toyo Inflation
Bdawg497
Atlanta, GA
For those of you running Toyo's; what PSI do you keep them at?
I just put on some AT2's this weekend. The installer argued with me about the proper inflation. I'm interested to hear other experiences at various inflation levels.
InTruckDesign
SW CT,
Best way is to chalk your tires and go for a drive, once adjust the pressures so that the chalk is worn off of the tread that is what you should run. And always air up the rears if you load it heavily or tow.
Bdawg497
Bdawg497
Atlanta, GA
Has anyone ever tried reading Toy's online inflation table? You need an advanced Engineering degree to understand what the hell they're talking about!
Zed 71
Pacific NW
I always do the chalk test as InTruck indicated above and have had even wear. It turned out for my Nitto Trails, it needed around 50 psi.
Post some pics!
CYKBC
what works for nitto trails has as much to do with what this guy should run with at2s as he should on what comes from the factory.
iirc, the heavier ply versions have a much higher max psi. i run high 30s cold. i've ran them mid 40s cold and find the ride comfort a tad better running lower so have stuck with it. i have the 285/60/18s which are not LTs but do have the more aggressive LT sidewall design. i know weird.
good choice on tires. best ATs out there in the market today imo.
Zed 71
Pacific NW
^ Geez take it easy. I was merely commenting on the chalk test and decided to post results for my tires as an aside.
Brendon post some pics!
CYKBC
Some people just align themselves to higher standards. Easy is as ez does bud.
Sent from my BlackBerry 9900 using Tapatalk
Bdawg497
Bdawg497
Atlanta, GA
I was running them at 35 psi for about a week, but have bumped them up to 39 and they seem to perform better.
Btw, had them up in the NC mountains this weekend in about a foot of snow and they performed great. Will try to get some pics up soon.
Bdawg497
Bdawg497
Atlanta, GA
Here's a couple quick pics of the new setup. These were prior to the trimming. Also a pic from this weekend in the snow.
CYKBC
cleanest z71 i've seen! perfect height. just the right amount of rake. very similar setup to mine except i'm lowered a bit and running 285/60/18s on 18" xd addicts. 1000% zero rubbing.
InTruckDesign
SW CT,
Really?? the only thing similar is that you both are running the same wheels, other than that they could not be more opposite...:signs8:
JamesinAbilene
