PPV??? SSV??
StevenW30
StevenW30
Chapel Hill NC
They have undoubtedly dealt with a lot of 6L80s that were in the K2 trucks, the generation after ours. Those have a different cooling system that typically kills those transmissions' torque converters after about 100K miles due to too much heat. These older 6L80s don't have that problem. People in general don't have great institutional memories.
Ok, that might explain why they said that at the dealership.... as far as towing, it's pretty consistent under heavier load (uphill, warm weather) but doesn't drop much otherwise. I was thinking a larger capacity pan with the new gears. Just replaced both oil and tranny cooling lines, had everything checked and looked good. This was done at my normal garage, not the dealership.
Marky Dissod
Next step is installing a bigger capacity transmission pan and 3.73 (camper towing).
My fluid temps get to 240°f, and I know these torque converter clutches have a history of not being the greatest.
Fixed it for you.
That said, you likely need to 'flip the pill' (CORRECTION: yours does not have to worry about this 'pill'),
and also should seriously consider an ATF cooler upgrade of some kind.
StevenW30
StevenW30
Chapel Hill NC
Fixed it for you.
That said, you likely need to 'flip the pill' ('fraid someone else'll need to give you more details about it),
Thanks! Swathdiver commented the dealership may have been thinking of a different trans... I had both sets of cooling lines replaced, mechanic said the cooler looked good, but I may start looking at an upgrade. The pan isn't terrible, about $300, and with my buddy we can do it.
mikez71
I'm still wondering how the dealership determined it was a PPV, guess they didn't run the vin and just said "yup"
Standard procedure for salespeople..
Tell 'em what they want to hear. Or just nod.
I'd be interested in learning what 1FL and 5T5 spell out.
All I could find, I think FL might be a fleet specification..
The 2022 PPV brochure says 1FL is required if you want the 9C1 package
1FL - PACKAGE FL OPTION 1
5T5 - SEAT OVERRIDE (SEO)
Thanks for the correction. More details, please, so I can get learned?
The K2s with the 6L80 and transmission thermostat have a different cooling system for the transmission. Their fluid goes into the cooler built into the top of the AC condenser and back to the trans. Because the fluid doesn't get preheated anymore like the old way of first going into the radiator, a thermostat was used as its substitute.
Those GMT900s with the external engine oil cooler (KC4) have a thermostat built into the lines coming off the oil pan to the radiator. Same design and concept.
Marky Dissod
Liking this would be damning it with faint praise. It deserves the 'Helpful' Check mark.
JoeBlobs
Senior Member
NJ
Hmm, interesting. This is a fleet designation but I thought it was reserved to Suburbans. I see now he doesn't have 5W4 nor the wiring options, so I stand corrected!
"5T5 seats, cloth front vinyl rear - Vinyl 2nd row rear seats and cloth front seats; if AS3 third row seat is ordered, it will be vinyl. Requires: AZ3 front custom cloth 40/20/40 bench seat or A95 front custom cloth high-back bucket seat, trim code 19D Ebony and PEG 1FL
OPTIONAL Front: cloth bucket with center console (power driver side seat only) A95 19C Rear: vinyl 60/40 split-bench 5T5"
Ebay Mike
Detroit MI
RPO CodeRPO Description
19CTRIM COMBINATION CLOTH, EBONY (C) (00)
19IINTERIOR TRIM EBONY (I) (00)
1FLPACKAGE FL OPTION 1
1SZDISCOUNT OPTION PACKAGE
50UPRIMARY COLOR EXTERIOR, SUMMIT WHITE (05)
5T5SEAT OVERRIDE (SEO)
6PBCOMPONENT FRT LH COMPUTER SEL SUSP (6PB)
7PBCOMPONENT FRT RH COMPUTER SEL SUSP (7PB)
A31WINDOW POWER OPERATED, ALL DOORS
A95SEAT FRT BKT, HIGH BACK, DRIVER & PASS RECL
AG1ADJUSTER FRT ST POWER, MULTI-DIRECTIONAL, DRIVER
AG2ADJUSTER PASS ST POWER, MULTI-DIRECTIONAL
AJ1WINDOW TINTED DEEP, ALL EXCEPT W/S AND DRS
AJ7RESTRAINT SYSTEM SEAT, INFLATABLE, DRIVER & PASS, FRT & SEAT SIDE
AL0SENSOR INDICATOR INFLATABLE RESTRAINT, FRT PASS/CHILD PRESENCE DETECTOR
AM1CONTROL SEAT, MANUAL LUMBAR, DRIVER
AM8SEAT RR BENCH, SPLIT STOWABLE
AP8LOCK CONTROL, ENTRY REMOTE ENTRY, EXTENDED RANGE
ARLPLANT CODE ARLINGTON, TX, USA
ASFRESTRAINT ROOF SIDE, LH & RH, INFLATABLE
ATDSEAT THIRD ROW DELETE
AU3LOCK CONTROL SIDE DR, ELEC
AXPVEHICLE TYPE MULTI-PURPOSE PASSENGER VEHICLE
BG9COVERING FLOOR RUBBER
BVESTEPS, RUNNINGBOARD SIDE
C25WIPER SYSTEM RR WINDOW, INTERMITTENT
C36HEATER AUXILIARY
C49DEFOGGER RR WINDOW, ELECTRIC
C69HVAC SYSTEM RR AIR CONDITIONER
C6AGVW RATING 7, 300 LBS
CJ3HVAC SYSTEM AIR CONDITIONER FRT, MAN TEMP CONT, AUX TEMP CONT
D07CONSOLE FRT COMPT, FLOOR, CUSTOM
DH6MIRROR I/S FRT VAN LH & RH, SUNSHADE, ILLUM
DK8CONSOLE ROOF INTERIOR, DELUXE
DL8MIRROR O/S LH & RH, REMOTE CONTROL, ELECTRIC, HEATED
E2CORDER TO DELIVERY EXPEDITE TO CUSTOMER
E52BODY EQUIPMENT ONE PIECE LIFT GATE WITH LIFT GLASS
EF7COUNTRY UNITED STATES OF AMERICA (USA)
FHSVEHICLE FUEL GASOLINE E85
FLTSALES PROCESSING OPTION
G63PROVISIONS LUGGAGE CARRIER, ROOF
GAMVEHICLE GOVERNMENT (G.S.A. SALES)
GU6AXLE REAR 3.42 RATIO
JD9BRAKE VAC POWER, 17" DISC/DISC, W/VSES, 7700 LBS
JL4CONTROL ACTIVE BRAKE
K34CRUISE CONTROL AUTOMATIC, ELECTRONIC
K5LEQUIPMENT Enhanced Cooling Package
KC4COOLING SYSTEM ENG OIL
KNPCOOLING SYSTEM TRANS, HD
KW1GENERATOR 160 AMP
LMGENGINE FLEXIBLE FUEL, (GAS/ALC), 8 CYL, 5.3L, SFI, V8 OHV, CYL DEACTIVATION, IRON, GM
MYCTRANSMISSION AUTO 6 SPD, HMD, 6L80
NE1CERTIFICATION EMISSION, GEOGRAPHICALLY RESTRICTED REGISTRATION FOR VEHICLES UP TO 14, 000 LBS GVW (USE 2003 MDL Y
NK5STEERING WHEEL STANDARD
NQHTRANSFER CASE ACTIVE, TWO SPEED, SWITCH ACTIVATED, ALUM
NU5EMISSION SYSTEM CALIFORNIA, BIN 4
NX7WHEEL 17 X 7.5, STEEL
NZ4WHEEL SPARE 17 X 7.5, J, STEEL, DESIGN 2
NZZSALES PACKAGE SKID PLATE, "OFF ROAD" SPOT
QGITIRE ALL P265/70R17-113S BW R/PE ST TL AL2 (PAFE)
R6QCONTROL SALES ITEM NO. 16
R9NCONTROL SALES ITEM NO. 89
R9RCONTROL SALES ITEM NO. 92
R9ZCONTROL SALES ITEM NO. 100
SAFLOCK SPARE TIRE, HOIST SHAFT
T74HEADLAMPS CONTROL AUTOMATIC, DELAY
TL1GRILLE SPECIAL
U2JDIGITAL AUDIO SYSTEM S-BAND "NOT INSTALLED"
U84ANTENNA BODY SIDE WINDOW, RADIO
UE0COMMUNICATION SYSTEM VEHICLE, G.P.S.---NOT INSTALLED
UJMTIRE PRESS INDICATOR MANUAL LEARN
UQ3SPEAKER SYSTEM PERFORMANCE ENHANCED AUDIO
US8RADIO AM/FM STEREO, SEEK/SCAN, CD, AUTO TONE, CLOCK ETR, MP3, RDS
V76HOOK TOW
V8DVEHICLE STATEMENT US
VGDFASCIA FRT, CUSTOM, BODY COLOR
VGEFASCIA RR, CUSTOM, BODY COLOR
VK3LICENSE PLATE FRONT FRT MOUNTING PKG
VR4TRAILER HITCH WEIGHT DISTRIBUTING PLATFORM
VT7OWNERS MANUAL ENGLISH LANGUAGE
WV9MERCHANDISED PKG VALUE LEADER
X88CONVERSION NAME PLT CHEVROLET
XL7FREQUENCIES RATING 315 MHZ, LONG DISTANCE
YD3AXLE (BASE EQUIP) FOR SCHEDULING GVW PLATE
YD5SPRING FRONT BASE EQUIPMENT
YD6SPRING RR, BASE EQUIPMENT
YE9CONVENIENCE PKG COMFORT & DECOR LEVEL #3
YK6IDENTIFICATION (SEO)
Z82TRAILER PROVISIONS SPECIAL EQUIPMENT, H.D.
ZRSTIRE SPARE P265/70R17-113S
ZW7CHASSIS PACKAGE PREMIUM SMOOTH RIDE
ZY1COLOR COMBINATION SOLID
In 2012, the 5-6 VIN positions are for the vehicle type. A K2 would mean a 4x4, 1/2 ton Chevrolet Tahoe Police Vehicle. This truck is a K4, meaning a 4x4, 1/2 ton Chevrolet Tahoe FL, or fleet vehicle.
RPO GAM identifies it as being built for government use. It did not originally come with a G80 locker, just 3.42 gears. Very common with Chevrolet.
Cool truck regardless.
Well I do not see the RPO Code 5W4 so it would not be an SSV? Now I am confused as I thought all the police 4x4's were SSV's?
StevenW30
StevenW30
Chapel Hill NC
All I know for sure is that it was a Homeland Security truck out of Texas, according to the paperwork from the previous owner that bought it at govt auction. No radio counsel, spot lights or warning lights ever installed, no evidence of plugged antenna holes anywhere.
opfor2
Riverside County, CA
C36HEATER AUXILIARY
TL1GRILLE SPECIAL
V76HOOK TOW
GAM= Vehicle Government (GSA Sales) so it's a US Government vehicle ordered by the General Services Administration and probably an admin fleet Tahoe since you don't have a 5W4 RPO code. VEHICLE GOVERNMENT (G.S.A. SALES)
In addition to @opfor2 information provided, the VIN also gives it away. The 5-6 positions are K4 and not K2. The latter is for a 4x4 Police Tahoe. The former is a 4x4 Government Fleet vehicle.
ZKWBQD
So, I was told by the previous owner and Hendrick Chevy that I have a 4x4 tow package PPV. Apparently, according to the dealership, Chevy did in fact make PPV models with those options. I was under the impression that 4x4 was automatically SSV. Not that it makes a big difference to me, but im running into issues with the garage I'm going to have replace the 3.42 gears with 3.73. They (the garage) want to confirm what trim they're dealing with. Im attaching the glove compartment codes for reference.
Thank you for any help....
Steve
EDIT* I'm not sure why, but I can't upload the image.... sorry about that!
The police package is nice. It is most likely the Daytime Running Lights have already been deactivated so you don't have to bother with that. Engine stop-start will also be deactivated so that'll save you another hundred dollars on the gadget that does that.
StevenW30
StevenW30
Chapel Hill NC
Yes, the DRL's are deleted... besides changing out the gears, maybe the torque converter, I'm almost done with getting it where I want it to be!
RooTBeeRthe1st
Hey y'all, thanks for the replies... I tried to post the RPO to as many as I could. I guess the dealership just looked at it and said "yeah, it's a PPV" Next step is installing a bigger capacity transmission pan and 3.73 gears (camper towing). My fluid temps get to 240°f and I know these trannys have a history of not being the greatest
More trans fluid probably wouldn't hurt, but an additional trans cooler definitely does the trick it is pretty easy to do if you already have the auxiliary trans cooler especially.
StevenW30
StevenW30
Chapel Hill NC
This 6L80 and 5.3 (DoD deleted but hardware still inside) has 276k miles. :)
And welcome, neighbor. I work in Orange County, live in Mebane....
Howdy neighbor! Chapel Hill here... Im at 160k, runs like new after all the work done. Not in search of more HP, but need to drop the trans temp when towing. Otherwise she's perfect!
kikeap
