PPV rear windows activation, need some help
cmatt
On the rear windows, can you control them (up/down & express down) from the driver switch?
Tim10
Tim10
Yes , they work from driver switch, but I didn’t figured out how express up/down works, so u know how to engage express mode ?
Tim10
Tim10
I just Looked again in manual how to use express feature up/down and it’s not working
cmatt
I did some research and verified with WAMS that it’s a programming issue. You’ve got the necessary switch and wiring. The BCM needs programming to enable the rear window switches.
You can contact them from their website www.whiteautoandmedia.com
Tim10
Tim10
Thanks, My research was telling me same thing that it needs programming.
Some people form older generation PPV swapped their switches and problem was solved...
03yukonxldenali
