Power Window Non-Op: Talk to me Goose!
IRQVET
2 Door Owners Club
Tallahassee, FL.
What am I over looking, probably something stupid. Driver power window is non-op, passenger side goes up and down just fine.
Fuse is fine.
Replaced the door switches (thought that would take care of it, but I was wrong)
Its a 2 door Hoe, and like I said the passenger side goes up and down just fine. But when I hit the driver side button, nada. No movement, no noises.
Fuse is fine.
I don't think those had computer modules operating them, did you test the motor itself yet? That's what I would do next.
east302
Mississippi
Agreed with the above. Pull the connector at the motor, see if you get voltage there when the switch is activated.
Multnomah Falls
You can also inspect for any wire problems at the door jam convoluted tubing where the hinges are. Possible rubbed thru wire insulation problems.
IRQVET
IRQVET
2 Door Owners Club
Tallahassee, FL.
I ordered a new relay that is suppose to arrive today. After I install that and see if the motor has juice and I’ll report back.
Do I need to disassemble anything to get to the motor?
Eman85
Switch works by reversing polarity to the motor so it runs the different directions. Do you have voltage and ground at the switch?
IRQVET
IRQVET
2 Door Owners Club
Tallahassee, FL.
Forgot to round back. Window is operational again but I have no idea why. Replaced the switch, didn’t fix it. So I pulled the door panel and began looking at the wiring and didn’t see anything wrong. My hand must have brushed against the motor wire, because it just started working all of a sudden. Lose wire?
Eman85
PW motors get wear on the armatures sometimes banging on the door or just slamming it jars the armature to a spot where it works, until it doesn't.
Off Road Pedia
