Power Steering suddenly gone
Adam OJ
Castle Rock, CO
2001 LT Tahoe
I was backing my trailer into the garage last night, and, with the steering at full lock, heard a loud pop. Got out, made sure I didn't hit anything, and tried again. I was greeted with a very stubborn steering wheel.
Ultimately, I was able to turn around in the cul-de-sac, just required a lot of muscle to do it.
I plan to fix this myself, but I don't want to just throw parts at it. What is the best way to diagnose? My thinking is that can still steer, just without any assist. So I would assume the box is OK, and the pump is bad?
Any other troubleshooting techniques?
Thanks!
A
Adam OJ
Castle Rock, CO
I'll reply to my own post...
I went in with the assumption that it is the pump. removed the intake, fan and fan shroud to expose the front of the engine. Removed the serp belt and gave a tug on the power steering pump pulley. Came right out of the housing. Pulley shaft broke up inside the pump. I have the new pump ready to go, just need the wife to get home with the other car so I can run out and rent a pulley puller :banghead:
Hope someone else can benefit from this.
-Adam-
Matt06Yukon
Not saying you did but alot of people do this, never hold the wheel at full lock. You'll hear the pump groan when you you do; back off a smidge. The psi increases alot when you do that and your straining the pump when you do that. Just a heads up.
Glad you found your problem.
A
Adam OJ
Castle Rock, CO
Thanks for the heads up. I have heard that before. That being said, I was backing my trailer into the garage (curved driveway, pushing into a tight single width garage opening. So I DID have it at full lock, and that is when it popped. Lesson learned...
brice715
