Marbor
Good evening to all
97 tahoe LT 5.7 no upgrades all stock
So this morning was pretty chilly and I used my remote start let it run for about 20 min before I headed out. Once in I noticed the wheel was pretty hard to turn but once I got going it seemed to get easy and no problems off to work. When coming home I pulled into the driveway in reverse and wow no power steering its tuff to turn took a spin around the block and no problems but when stopped and turning it it goes a little then gets harder.
I parked and looked for leaks, checked fluid no leaks and full of fluid. With hood up i had my daughter turn the wheel and I see the hose jump but also hear a small wind as if there is no fluid.
No grinding from the wheel pully all seems fine when at idle but once turning there's a little his and no power. Any known problems with this ? What else can I look at to figure this thing out before winter hits?
