Picked up a ZZ4 engine
99 2dr
The Real Nor Cal !
Hey Guys I was at an auction over the weekend and I picked up two brand new ZZ4 crate engines. They are the 355hp 400ftlb model. I would like to put my sitting my heads,intake, ect..... on them and dropping it into my Tahoe. My 64 cc vortec heads should lower the compression enough to run 87 and the vortec heads outflow the L98 heads. Both engines have the plastic front timing cover and crank sensor location like the vortec block. Of course I would need to have BB tune the computer. I think that my stock fuel system with the upgraded injection spider should be enough. For those of you in California, how big have you gone motor wise and still made it past smog inspection? What do you guys think? I got them both for the price of one new one. If for some reason I cant use one in the Tahoe, I have plenty of other projects. Just too good of a deal to pass up.
ZZ4 350 TURN-KEY TECH SPECS:
Part Number: 12499712
Engine type: Chevy small-block V-8
Displacement (cu in): 350
Bore x stroke (in)cf6 : 4.00 x 3.48
Block (P/N 10105123): Cast iron with 4-bolt main caps
Crankshaft (P/N 12556307): Forged steel
Connecting rods (P/N 10108688): Powdered metal steel
Pistons (P/N 10159436): High-silicon aluminum with offset pins
Camshaft type (P/N 10185071): Steel hydraulic roller
Camshaft lift (in): .474 intake / .510 exhaust
Camshaft duration (@.050 in): 208'c1 intake / 221'c1 exhaust
Cylinder heads (P/N 12556463): Aluminum; 58cc chambers
Valve size (in): 1.94 intake / 1.50 exhaust
Compression ratio: 10:1
Rocker arms (P/N 10089648): Stamped steel
Rocker arm ratio: 1.5:1
Recommended fuel: 92 octane
Ignition timing: 10'c1 BTDC @ 800 rpm, cf0 32'c1 total @ 4000 rpm with vacuum advance disconnected
Maximum rpm: 5800
retorq
Kingman AZ
You'll need to do some work on those Vortecs to use that cam ... will be a good overall engine once tuned properly. :D
:popcorn: I'm in for this swap!!!! Nice job on the deal man :)
99 2dr
99 2dr
The Real Nor Cal !
Retorq, I was thinking some port-polish on the heads and some new springs. Do you have anything else in mind. My main concern is getting it to pass smog. Any other California guys running a big cam and getting it to pass? If so, how big is it?
98blackbell
FL
Great find, that will be an awesome upgrade for you tahoe
Gzes
the drifting 2dr
Wichita tx
I got a great idea. Leave stupid cali and no more smog inspection:) here in tx we dont care plus you can mod the motor up more and be good:) nice 2dr by the way. Looks like mine exept urs is all white
99 2dr
99 2dr
The Real Nor Cal !
Well I'm kinda stuck here in California. Believe it or not, there are several counties in California that don't require smog inspection. Mine is not one of them. My trans is currently built fairly stout however I'm thinking that it wont last too long with the new power and all the towing I do. As soon as a NV4500 finds its way into my shop,the swap will begin. Here is a shot of the TWO ZZ4's and a pic of the Tahoe from an outing this weekend.
Gzes
the drifting 2dr
Wichita tx
They look sexy and the hoe is also sexy. U making it a street truck or making it into a badass lifted hoe that can beat tue shit out of any ford. Mine can beat a ford right now and its broken:)
99 2dr
99 2dr
The Real Nor Cal !
The truck is just a daily driver. I Cranked the front bars up to level it out about 150,000 mi ago and I have no plans of lifting or lowering. I am on the look out for a set of 18's off a 2007-2010 silverado but that's about it.
I bought both of the zz4's at an equipment auction in Vallejo, Ca. Two for the price of one.
foreverfalcon40
Eqipment Auctions sounds good? How did you hear about it? Going to check around NY...need a compressor too!
99 2dr
99 2dr
The Real Nor Cal !
Yup! Equipment auctions often have small estate items, tools and air compressors. I have purchased a couple muncie's for under a hundred before. Most people are at the auction for Bobcats, forklifts ect.
foreverfalcon40
I live in NY, how do you find these out? I have been to couple of town auctions( local town auctions off thier beat to shit trucks, vans and equipment)
99 2dr
99 2dr
The Real Nor Cal !
Try and Google "equipment auctions NY" or "construction auctions NY" you should be able to come up with something.
Brace
